i need some advice with this cooling fan
Old Jun 7, 2012 | 07:19 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
My car has been overheating bad lately. It cools down when I stop, heats up when I drive. I do not have an air dam, but do have a functioning grill. Outta curiosity, I checked the direction of my fan, and its blowing through the rad towards the front of the car. So when I start moving, I'm canceling out the fan.
This is my guess. Here is a pic of the label on my fan. The arrow is pointing towards the frontof the car.
I pulled the shroud to see if I could do anything about air direction and noticed how the fan is pinned to the radiator. These look like one time connections. I'm afraid to break them with too much force. Here's the front.
And here is the back.
I have the transmission cooler in front of the radiator. My thoughts are that I either buy a new, correct fan, or figure out how to remove this one and mount it to the front of the trans cooler, so it blows correctly into the engine bay.
Am I correct in my line of thinking? Has anyone dealt with a fan like this and knows how to remove the pins without breaking them? Can I mount this thing to the front of the trans cooler?
I need help with this fast, and appreciate your time.
Old Jun 7, 2012 | 07:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: i need some advice with this cooling fan
the pins are like zip ties one time use, you should start by installing a air dam. you can but the mounting zip tie deals Flex-a-lite 3915, tci 821500 many others
Old Jun 7, 2012 | 07:34 PM
Dezined's Avatar
Engine: L98 5.7l V8
I believe the first thing I need to do is get it blowing the correct way. I spend most of my time driving 40 MPH or less. I have read the air dam only makes a diff at highway speeds. Is that wrong?
Can the fan be mounted in front of the cooler?
Old Jun 7, 2012 | 07:46 PM
Engine: Lb9
Transmission: M20
according to the sticker it is a pusher. You might install a duel electric puller fans on the single fan. guys in the classifieds are parting out thirdgens.
Old Jun 7, 2012 | 09:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
on many of those fans,the fan blade can be unclipped
from the motor,flipped over for correct blade rotation,
and the motor connected for correct rotation.
A fan pulling through the radiator is much more
effective than the same fan pushing air through the
radiator from the front-this is because the fan imparts
rotation upon the air it propells,causing the air to hit
the tubes and fins at an angle-reducing velocity.
Old Jun 7, 2012 | 09:41 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
simplest/cheapest - move the fan to the front. Dremel tool to cut the plastic pins, prob have to extend the wiring to pin it to the front? Make sure it fits in front first and find new pins before starting. air dam works when yr moving, creates vacuum behind it helping pull air through the rad.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
