should I yank the a/c or easy fix
Old Jun 9, 2012 | 05:16 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
should I yank my a/c or this is an fix if it's even broken at all. the guy before me said it doesn't work he hasn't tried it. I just got hot air when I turned it on. what you think?
Attached Thumbnails should I yank the a/c or easy fix-imag0544.jpg
Old Jun 9, 2012 | 05:30 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: should I yank the a/c or easy fix
Does it get hot where you live? Do you keep your windows down when driving most of the time? If it blows, sounds like compressor works. Has it been converted to 134a? R12 can be expensive. But to convert is a pretty cheap fix. I would not be without a AC.. Az is really hot. I would see if the ac is in working order before you pull everything out. If it just needs a charge that would be great!
Old Jun 9, 2012 | 06:12 PM
jaybdaboat's Avatar
Lately its been getting 90+ the ground gets to hot so you can imagine my camaro. I really don't have a choice but to roll them down and drive as fast as needed. They chopped off emissions so I'm not sure if everything's stock or not.
Old Jun 11, 2012 | 11:04 AM
jaybdaboat's Avatar
Bump
Old Jun 14, 2012 | 06:51 PM
Braxton16's Avatar
Car: 1992 camaro rs
Engine: 305 v8 stock
Transmission: automatic stock
at walmart they have a r-12 to r-134a retrofit kit for like 40$ and its super easy!! took me maybe 10 minutes and it works like a charm now! it called ez-chill retrofit kit.
Braxton16's Avatar
Car: 1992 camaro rs
and if it dosent work your only out 40$
Old Jun 14, 2012 | 06:56 PM
Engine: MPFI
Make sure all the components are there. If your not sure, research, get a Haynes book and look into it. Then make a decision.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
my86bird
Oct 23, 2015 12:20 PM
Ironhead38
Sep 7, 2015 02:26 PM
L0tuS
Sep 4, 2015 11:16 PM
85Special
Sep 3, 2015 04:21 PM
