Coolant Temperature Sensor Location
Old Jul 15, 2012 | 09:08 PM
blackbirdy's Avatar
Car: 99 Pontiac Trans Am
Hi everyone. I have a 99 Trans Am, 5.7 V8 engine. My cooland level keeps staying on and I was told that it is the coolant temperature sensor that is causing it. Can someone tell me exactly where this is located? Thanks in advance.
Old Jul 15, 2012 | 11:40 PM
Mad Max's Avatar
Car: 1984 Z28 h.o and 1991 RS
Engine: 305 h.o in the z28 & 350-RS
Transmission: t5 & 700r4-RS
Axle/Gears: 7.5 10 bolt posi 3.73 & 4.10 RS
Re: Coolant Temperature Sensor Location
You actually should have two, the sensor and the sending unit. If the sensor is bad it would likely have a high idle and it is located on the thermostat housing. The sending unit is on the block on the drivers side between the 1 and 3 cylinder, it only goes to the gauge.
Old Jul 16, 2012 | 03:14 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Cylinder 2 is on the right side of the engine and cylinder 3 is on the left. On an LS1, the coolant temp sensor is inbetween cylinder 1 and 3, but that sensor is unrelated to a coolant level warning light.
The sensor for a coolant level is in the right side tank of the radiator. Most likely problem is that your coolant is dirty, and the sensor is fouled. System flush and a cleaned sensor might solve it.
Jorlain
Oct 8, 2015 01:57 AM
hydrolic144
Oct 4, 2015 08:23 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Bstrang6
Sep 8, 2015 04:29 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
