Engine running at about 160 deg f is that "bad"?
Car: 1984 Z28 h.o and 1991 RS
Engine: 305 h.o in the z28 & 350-RS
Transmission: t5 & 700r4-RS
Axle/Gears: 7.5 10 bolt posi 3.73 & 4.10 RS
As far as the engine lasting and the car getting me places is concerned I know its not a problem, it gets warmed up.
I recently set up my electric fan so it is always on when the car is on, I was having issues with it not turning on and the car overheating. Now it sits at the line between 100 and 220 (I assume that's 160), and my guess is that's when the thermostat is opening (the last owner told me he put in a "performance" thermostat in it). Does this affect anything and should I go get a higher temp stock thermostat? I know this is well below normal operating temp.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Engine running at about 160 deg f is that "bad"?
Sorry dude, found that amusing
. Did it come with a go-fast sticker?You've noticed one problem with the stock temp gauge - gawd knows what it reads exactly, there's no consistent graduations on it, you have to kind of make an educated guess. Get a laser temp gun and shoot it around a bit, see what it says.
I'm thinking of going out and getting a 180 deg or stock thermostat just so its "right" but that's just my OCD side. Is there any advantage to doing that?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i have 195 thermostat in mine and it runs right around that center mark.
Belt driven fan so"always on"
Engine: 4++,350 & 305 CIs
Grab a lazer temp gun and check the temp right on the t-stat husing while the car is warmed up.
theshackle
Mar 5, 2017 06:37 PM
