Dual 12" fans or stock fan?
Old Jul 19, 2012 | 08:42 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
My car is a 1985 Camaro that came stock with one large (not sure the diameter) fan. I swapped out the motor for a 383, brand new water pump, 180 F thermostat, no A/C, new 3 core radiator.
The radiator came with dual 12" fans that I was planning on using, one running from the computer and the other either on a temperature sending unit or on a switch I could manually turn on and off.
Now that I have everything installed, I'm wondering if I'd be better off just sticking with the stock fan - can bolt it right on and be done. If I go with the dual ones, I have to mount, worry about wiring, etc. But...I want to do whatever is going to work best. Any thoughts?
Old Jul 19, 2012 | 09:12 PM
Mad Max's Avatar
Car: 1984 Z28 h.o and 1991 RS
Engine: 305 h.o in the z28 & 350-RS
Transmission: t5 & 700r4-RS
Axle/Gears: 7.5 10 bolt posi 3.73 & 4.10 RS
Re: Dual 12" fans or stock fan?
My stock one works great. I set it up so its always on and my car runs right at when the thermostat opens.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
