Plug for fan switch completely stripped...options?
Car: 91 Formula
Axle/Gears: stock
My heads came with a plug in the port where the fan switch goes. Unfortunately, it is completely stripped out. It will be in there forever. Are there ANY good options for somehow wiring the fans without the switch in that location? I have a 1991, so dual fans. Please help!
Car: 91 Formula
Axle/Gears: stock
Re: Plug for fan switch completely stripped...options?
I want to get that thing out so bad, it looks hideous. But I can't see any possible way, couldn't really get a drill down there to drill it out, even if that was a good idea.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
pull the manifold off and weld a nut to it. the heat will loosen it and should come right out.
Car: 91 Formula
Axle/Gears: stock
That is a lot of work (having to remove head) but it sounds like a plan. I guess there is no way to get it out while the head is still installed? No chance an easy out would work?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
is the plug a brass square plumbing plug? Also got any pictures?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If getting it out ain't gonna happen, you can use an aftermarket switch with a radiator probe or find another port on the manifold to screw one into.
It might If the plug is brass you cannot weld to it but drilling would be easy got any pics?
Car: 91 Formula
Axle/Gears: stock
The plug was steel. Thankfully we were able to weld a large nut to it (had to keep moving up in sizes until it finally worked) and it came out, but not easily! It still took quite a bit of force. Thanks for the suggestions!
Glad it was steel and you were able to get it out
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Malox (the antacid) is a good anti seize.
eightsixseven
Dec 16, 2024 01:50 PM
Terrell351
Jun 13, 2021 01:13 PM
TA8487
Aug 16, 2015 12:21 PM
