New relay= radiator fans work but only for a min
Old Sep 19, 2012 | 02:01 PM
thegoon1969's Avatar
OK so my radiator fans stopped working in my camaro. I checked for power at the fans, no power, i check for power at the fuse and i have power, i check for power at the relay and i don't have any power. I replace the fan relay and the fan kicked on right away, it ran for about 2 min then quite working again. If i put another new relay in it will work for 2 min then turn off. hmmm??????
Old Sep 26, 2012 | 04:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Welcome To The Fan Club
Test the relays which caused the fan to stop after 2 minutes.
Apply power to the coil to see if they still pull in.
Also when you install the next relay, monitor both the coil power in and the main power in, with meters or test lights
(the type for testing for voltage, not a continuity tester).
This way you can see which leg of the circuit is dropping power.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Leggman1
Aug 6, 2015 04:15 AM
