Lower rad hose collapses under rpms
Old Oct 5, 2012 | 11:22 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
So...here I am again!
When I push some rpms to the newly reborn 350, the lower radiator hose collapses under the vacuum. I know the spring is probably rusted away to nothing and the hose needs replaced...(I havent taken it apart yet)
I was going to get one from Rockauto but I wanted to make sure the replacement had the spring in it, do they all? (yes I already read the article about the spring only being useful in the factory setting, but thought I should ask anyway)
Old Oct 5, 2012 | 11:50 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Lower rad hose collapses under rpms
It should come with the spring. Do you have a thermostat installed?
Old Oct 5, 2012 | 11:52 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Yes, thermostat is installed, I can see flow through the radiator, just when I rev the motor, the lower hose collapses.
All lower hoses come with the spring? I thought I read that some manufacturers didn't?
Old Oct 5, 2012 | 12:05 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Additionally, the second fan never came on, even when I turned on the AC. Ill have to troubleshoot that when I get some more time. Its not going anywhere, unless someone steals it
Old Oct 5, 2012 | 12:34 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Your system seems to flow good then. The second fan comes on when the A/C compressor head pressure reaches a certain level. It's not just the A/C being on that does it. It also can come on when the cylinder head temp switch commands it, which is at an equally ridiculous temperature.
Old Oct 5, 2012 | 12:43 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
One more thing. You don't really need the second fan. Since my A/C doesn't work right now (leaked down decades ago), I never hear my second fan. I'd be turning the engine off before it ever got hot enough to kick on. This isn't NASCAR so I don't think 245F is a reasonable temperature to turn a fan on.
I switched my thermostat and now will reprogram my ECM to turn the primary fan on at a decent temperature too. I'll probably switch my cylinder head temp switch for a lower temp as well. 200F-210F sounds allot more like the time to turn on the second fan.
1992 Trans Am
May 10, 2023 07:19 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
