Where does this connector for the guage sender go?
Guest
Posts: n/a
I need to know where this goes SPECIFICALLY. I have looked and cannot find its connection. It's just hanging there. I also need to know where the temp sensor for the computer is. Thanks guys I'm just really frustrated my Camaro is running rich cause the ECM thinks the engine is cold.
http://www.hawksthirdgenparts.com/pr...I-%26-TBI.html
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where does this connector for the guage sender go?
that connector is for the gauge and goes in the drivers side head between #1 and #3 cylinder. The ect is in the front of the intake manifold.
Engine: Lb9
Transmission: M20
you can see the ect is under the coolant bypass fitting
Guest
Posts: n/a
There is no place in the head between the number 1 and number 3 spark plugs for me to plug the connector in. Not that I can see. Between the spark plugs 1 and 3 all I see is a brass plug looking thing that looks the same as the cooling fan switch on the other side of the engine.
Engine: Lb9
Transmission: M20
is this tbi ? that brass thing is the temp sensor for the dash gauge and uses the connector like you posted in the first post. the connector slides on the nail head at 90 degrees. If this is tbi the ect in in the intake as well.
Engine: Lb9
Transmission: M20
I have never seen the cooling fan switch used on tpi just tbi and ccc, unless someone has swapped the heads or done a tbi to tpi conversion.
TMZIrocZ350
Oct 7, 2015 12:09 PM
