Original Radiator Cap Needed
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
Where can I find and original cap. Mine has 15PSI and Made in Britain on it. I don't think it is original. It should be 16PSI. and all the a/c deloc caps I find are 15 pound settings and in plastic. Any suggestions?
Engine: 4++,350 & 305 CIs
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Original Radiator Cap Needed
I run a Murray radiator and a Murray 16 lbs cap.
http://www.oreillyauto.com/site/c/de...2021&ppt=C0331
Engine: 5.0 TPI
Engine: 5.0 TPI
It is stamper Made in England and 15 LB Closed System.
I'm going to have to check my cars when I get a min in the morning but that looks like the correct style..
Engine: 5.0 TPI
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
That's definitely not original. GM still sells original ACDelco caps. I bought one a couple of weeks ago from the GM Parts store
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I think this is an original rad cap since the whole car has been very original so far, but I can't be 100% sure:
Transmission: 5-Speed Manual
That Is The Factory Original 15 LB Cap My 1984 Came With Not Sure If All 1982-1992 3rd Gens Had Them GM May Have Made A Change Over The Years.
Engine: 5.0 TPI
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
I bought a genuine AC Delco relay (Fuel pump) from a trusted TPI supplier. MADE IN CHINA. nice AC Delco Box tho... Even Delco branded things will be made just about anywhere these days... Delphi is completely global now. That's not all bad either. Unless you are facing some judging scrutiny. Is not my USA Apple Iphone made in China!? My new relays? my Corvette brake rotors.... at some point this will be acceptable on concours. Just make sure they spell "NEVER OPEN HOT" correctly... LMFAO
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm curious as to what it matters ?
1lb of pressure won't make or break the cooling system.
I can't imagine a radiator cap collapsing the value of the car either.
Not being an ***, just wondering...
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
