squeeling ac compressor
Old Nov 17, 2012 | 01:39 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
when i baught my car a year ago the ac didnt work. i know the compressor is bad. everytime i start my car it squeels like you cant beleive. the squeeling stops after about 20 minutes of running but i usually use wd40 to stop the squeeking all together. i know that this isnt good for multiple reasons but i cant stand the squeek. how can i perminantly stop the squeeling. i have a 2.8l 88 rs
Old Nov 17, 2012 | 06:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: squeeling ac compressor
Well, you have 2 options. Either way, that compressor pulley bearing is going to seize.
1. If you want working A/C at some point, replace the compressor.
2. If you could care less about the A/C, yank the compressor after making sure the system is empty and reroute the belt.
But, before doing that, check the belt tension by looking at the marks on the tensioner. If the arrow on the tensioner is outside the scale on the top of the housing, you need a new belt and that's why it's squealing.
Old Nov 18, 2012 | 04:57 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
"yup"
Start with the cheaper option first, just because a compressor leaks or doesn't work, doesn't mean it'll cause a belt squeak. In fact, it would "rattle" more squeal. More of a sqeak/rattle than a squeal.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
