serpintine belt system on 400sbc
Old Nov 18, 2012 | 10:32 AM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
I am sure this has already been covered but I havent had any success searching. I have an 84 camaro with a 400sbc. It currently has a v belt set up. I want to install a serpintine sysem out of a 89 firebird. The water pump appears to spin in the opposite direction on the serpintine system. What do I need to do for this set up to work and cool the engine properly.
Old Nov 18, 2012 | 11:20 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: serpintine belt system on 400sbc
Use the water pump from the serpentine setup. It does spin backwards compared to the v belt one.
Old Nov 18, 2012 | 04:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Just order a water pump from an 89. The serpentine water pumps are "Reverse Rotation", so they do spin backwards, but flow the same way as your 84 pump.
I have an 88 Serpentine Set up on my 84 Firebird and had the same question. Just make sure you get one for an 89 because if you get one that's "Reverse flow", you're wrong. Remember, REVERSE ROTATION, not "Reverse Flow (These were on LT1 Motors).
Old Nov 18, 2012 | 04:41 PM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
Thanks for the replies. I was confuzed on that. I will exchange the one on the firebird for a new one at the parts store.
Old Nov 20, 2012 | 01:38 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I got a 400 in my 90 iroc and you have to use all 88-92 parts like water pump, alternator, etc.
Old Nov 20, 2012 | 07:21 AM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
I am pretty much going through the entire car. The power steering pump is shot. I am going to pull the engine and clean up the engine compartment because it look terrible right now.I like how much cleaner the serpintine set up looks.
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
