An odd duck that needs to be cooled.
Old Dec 4, 2012 | 08:17 PM
Cruz7_11's Avatar
Car: 1988 Camaro RS
Engine: 305 Dueljet carbureted
Transmission: 700R
Axle/Gears: Stock
Okay so about 2 months ago i "accidentally" blew up my 2.8 Camaro rs. Well, me and my dad decided to swap the 2.8 standard to a 305 carb/headers/ exhaust system/ automatic. So that was all fun and hell, but were pretty much done now. pretty sweet. feels powerful to me. but we have this issue that the (what i think) is the thermostat is not opening. i think this is because there is very little water in the top hose. maybe, maybe not. i was just thinking maybe someone else knew a little bit about this. oh, and is there anyway to trip the fan to run all the time?
Old Dec 5, 2012 | 06:04 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: An odd duck that needs to be cooled.
Pull the rad cap off start your engine and look into the rad. If the water is moving around then its your t-stat if its not moving water pump. Make sure youre completely full of coolant. Yes you can qire direct power to your fan. Install a switch in the car if you want.
Old Dec 6, 2012 | 02:32 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You never said why you think the thermsostat isn't opening. Is the car overheating? How did you determine there is "very little water in the top hose?"
When you open your radiator cap, is the radiator full?
Mark_ZZ3
May 24, 2018 01:02 PM
okfoz
Sep 12, 2017 11:48 AM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
