thermastat ?
Old Dec 28, 2012 | 10:54 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
thermastat ?
The temp sender is on the block and the thermastat is at th top. my temp goes dangeriously hot befor the stat opens. the stat has been replaced 3 times and does the same thing. i've gotten a bad part new befor thats why 3 times. are the temps the same? am i boiling the wtr in the block and the water at the stat is still cold? when it opens it reads about 1/4 of the way up and controlls there. the fan starts rite at 195. thats why i think the sender is reading rite.
the old motor started useing wtr so i think this is bad. i have a new motor now and i want it to work.
Old Dec 28, 2012 | 11:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: thermastat ?
Have you burped air out of the system?
What temp does the fan come on?
Can you get a temperature gun & get a true reading of the heads, t-sat houseing & hoses?
hasty88-and-89
Jul 23, 2010 06:40 PM
szathmari
Nov 17, 2005 09:27 PM
irocbarry
Jul 16, 2003 11:12 PM
91blkta
Mar 16, 2002 07:04 AM
