Aftermarket coolant temp gauge help.
Old Jan 22, 2013 | 12:31 AM
87 Camaro Dude's Avatar
Car: 1987 Camaro SC
Engine: 2.8L V6
Alright so I got a mechanical temp gauge and I can't seem to find a place to screw the end of the capillary tube into the engine. By the way this is with the 2.8 V6, as I've found plenty of threads that deal with the V8s on this subject. Basically the only place i can find is on the front of the intake near the thermostat, but there is already some kind of sensor with a yellow and black wire coming out of it. I assume there has to be another place I can screw this thing in, right? And what exactly does that sensor do? Because if all it does is control when the fans come on then that doesn't affect me since mine runs off of a toggle switch anyways.
Thanks in advance guys!
Old Jan 22, 2013 | 12:39 AM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: Aftermarket coolant temp gauge help.
That wire is for a sensor that should run the temp gauge itself if i am correct!
Old Jan 22, 2013 | 11:00 AM
Car: 1987 Camaro SC
Engine: 2.8L V6
You're probably right, but I want to run this gauge mechanically not electrically.
Old Jan 23, 2013 | 06:19 AM
Car: 1987 Camaro SC
Engine: 2.8L V6
Anyone?
Old Feb 14, 2014 | 10:57 PM
Mwiasb's Avatar
I have a 87 2.8... I have a hole in the torque converter housing between the trans pan and the oil pan. Coolant leaks right out of it. I thought it was a sensor but after hours of searching... I think it was a aftermarket coolant temp gauge or I have a 3.1/3.4. I can tell it's had a engine swap. It might be what your looking for. It's raining or I would show you a pic.
Old Feb 15, 2014 | 01:58 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The sensor with the black and yellow wire needs to stay, computer needs the input.
Not too familiar with the V6, but in your case you can use the fan switch or the original guage sender, I don't know where they are located.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
GTAman
Sep 21, 2015 09:57 AM
Bstrang6
Sep 8, 2015 04:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
