Air only coming out of defrost the same for digital a/c?
Old Jan 25, 2013 | 10:45 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I have a 87 Trans Am GTA with the digital a/c controls. Never blew cold air, but always used to get air from the vents, now it only blows through defrost. Has been like this some time but haven't worried about it since the car was down.
I've read about the vacuum control valve but I don't believe I have that. What would be my next option? Any others with digital a/c had the same problem?
I checked the vacuum line coming from the passenger firewall going to the heater control valve and it was fine. It used to suck air, but now it gets nothing at all. Any help would be greatly appreciated.
Old Jan 26, 2013 | 03:52 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: Air only coming out of defrost the same for digital a/c?
Mine did the same thing..stuck vaccuum check valve. Might be worth checking out.
Old Jan 31, 2013 | 09:32 PM
Replaced that awhile back. Swapped in a engine from a 91 Z28, and now it seems I only get air from the defrost and the floor?
Old Jan 31, 2013 | 10:25 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have the same problem and I too would like to know.
Old Jul 20, 2013 | 05:02 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Stuck with the same problem too
Old Jul 20, 2013 | 07:45 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
IIRC when the HVAC system malfunctions it goes into the default mode and blows out the defrost vents.
Check the vaccuum source line/check valve or behind the controls.
lakeffect2
Aug 23, 2015 08:44 AM
tartagliaz28
Aug 15, 2015 10:59 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
beachrodder
Aug 7, 2015 04:27 PM
