water level and temp
Old Feb 19, 2013 | 12:37 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Hey guys, did a lot of testing last year on different fans, stats, etc trying to find the best combo and I accidentally found out some more. I have a seeping head gasket and my water level fell about three inches low and my temp went up about ten degrees. I figure this was not using about two rows of tubes so a good guess would be about 5 degrees per row of cooling tubes.
Old Feb 19, 2013 | 09:54 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: water level and temp
Not really a scientific measurement if you had a blown head gasket. That alone can make it run hotter. A good running car 3 inches low on water should run the same temp. The radiator just has to work a little harder.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
