Coolant bottles the same?
Old Feb 21, 2013 | 12:50 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I did a search and did not find anything. The coolant overflow in my 92 RS 3.1 has a very small crack at the lower mounting screw. I maybe be able to seal it up-have not looking into it yet, but the question is-is the coolant overflows the same on a v8 car as a v6? Also did they change over the years? I might go to Pull A Part this weekend and would not mind pulling a bottle while there.
Old Feb 21, 2013 | 12:52 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Coolant bottles the same?
Yes They Did Change Over The Years
Old Feb 21, 2013 | 12:56 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I think something changed around 87?
Old Feb 21, 2013 | 01:02 PM
2007xl50's Avatar
Engine: LB9/3.1
Well the one yard has a 91 Camaro in, not sure what engine is in yet and did not want to get the bottle home and not have it fit.
Old Feb 21, 2013 | 01:10 PM
Car: 1971 Camaro
Engine: 427
From what I have seen listed, 89-92 are the same.
Old Feb 21, 2013 | 01:17 PM
2007xl50's Avatar
Engine: LB9/3.1
Cool-thanks they also have an 89 there that I have pulled some parts from already. I think I'm going to stop in there as I am going by the exit for that yard anyways-that's a fast easy part to pull.
Old Feb 21, 2013 | 01:34 PM
gt4373's Avatar
Here's An Example Later Years Were Much Larger
Attached Thumbnails Coolant bottles the same?-mytamotorlookingsweet.jpg   Coolant bottles the same?-photobucket-1023-1341863573523.jpg
Old Feb 21, 2013 | 01:39 PM
Car: 1971 Camaro
Engine: 427
Wow those later ones are huge!
Old Feb 22, 2013 | 12:22 PM
2007xl50's Avatar
Engine: LB9/3.1
Yeah my TA has the smaller one and my Camaro has the larger one. So as long as I get the larger one I'm set. It's crazy how GM did so many little tweeks to the 3rd gens over the 10 year span.
Old Feb 22, 2013 | 01:11 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
So did you get one?
Old Feb 22, 2013 | 01:28 PM
2007xl50's Avatar
Engine: LB9/3.1
Going to the yard tomorrow to see if there is a nice looking one. The one in my Camaro looks nice and clean, but has a slight leak where the OP cracked it, I might be able to seal it up, but if I can get a nice bottle for $5.00 at the yard then I would rather go that route. Sucks that I'm going to the yard on the way to the new car show as i will be in nice cloths and on limited time so not going to be able to pull alot of parts like I want to. I am going to try to pull the GFX door section from the passengers side as long as it there since my is warpped a bit.
Old Feb 22, 2013 | 10:07 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
As far as I've seen, the reservoir changes were made with the change from v-belt( +hybrid in 87), to serpentine. The washer fluid pump went from motor mount pump to tank pump as well.
Old Feb 23, 2013 | 08:02 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
the mounting from later to earlier style is the same, so they will both bolt in, i used to have an earlier style on my 91 camaro and it worked just fine. dont know if they larger will work on the earlier style tho because of clearance.
Old Feb 24, 2013 | 11:00 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Why waist your money at a JY when you can get new!!!
http://www.hawksthirdgenparts.com/pr...roduction.html
Old Feb 25, 2013 | 09:33 AM
2007xl50's Avatar
Engine: LB9/3.1
Why? The new one is $40 plus shipping and one at Pull A Part is $5.00. I went to the yard and both the 89 and 91 has no bottles in them. The 84 Trans Am had a nasty looking old style bottle in it so I left it. I may just pull mine out and try to seal it as it's a very slight leak by the one screw tab.
Old Feb 25, 2013 | 11:44 AM
Richboll's Avatar
Engine: 305 TBI
Here you go...
http://www.ehow.com/how_5606749_fix-...ank-leaks.html
Old Mar 4, 2013 | 09:06 AM
2007xl50's Avatar
Engine: LB9/3.1
Ok I feel dumb as hell. I was at the yard this weekend and there was a 92 Camaro 3.1 there that had a bottle in it. All the screws werer off, but there is a bolt/stud inside the bottle that hold it to the strut tower. I could not see how to get in the bottle. I did pull the fender liner and seen the 10mm bolt that goes to that stud, but it just spun and spun and I never did get the bottle off the car-it was 27 out and I was getting cold and had to get going. So what's the trick to get the bottle out?
Old Mar 4, 2013 | 10:18 AM
mantaguy's Avatar
Engine: 5.0 EFI
That $40.00 doesn't sound to bad now,that's why I say,if you can get a new part now,jump on it.
Old Mar 4, 2013 | 11:06 AM
2007xl50's Avatar
Engine: LB9/3.1
Still sounds bad as I still need to get the one off my car so really this was no help. Oh well I will get it at somepoint. My bottle is not leaking bad at all, very very slow so no big rush. Plus my Camaro is a budget car so anytime I can save money with used parts I will. I mean some stuff I'm going new, but body stuff, coolant bottles and stuff like that-used is fine.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
