Heater Control Valve
Old Mar 2, 2013 | 04:57 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Last night started up, let warm, shut off cause SES light was on, usually when I restart it goes out ..... Stupid EGR .... or IAC, once hot light goes off on restart.
did that and got to corner of my street and saw steam/white smoke coming out of the front hood, turned around - back into garage, pop hood, only place I saw AF was at base of heat control valve thing, dripping on manifold.
This morning started, ran, drove it this morning, no leak ????
Ran it hard for about 8 miles ... no problem
Was this just from a quick restart ?
I bought a new one just incase (16.99)- has this happened to anyone else ??
Old Mar 3, 2013 | 08:25 AM
Car: 90 Iroc Vert
Engine: 5.0L
Re: Heater Control Valve
Bump ... anybody have a spiratic prob w/ HCV leaking ?
Mine just did as explained above. Wierd.
Old Mar 3, 2013 | 09:25 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Water leaks can come and go depending on component material, temp and pressure conditions. Your diverter valve is located at one of the highest points in the system, and if you're water level is down, the leak may appear to be cured.
Old Mar 3, 2013 | 12:06 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I went through about 3 of those things before I got fed up with them cracking and deleted mine and put a manual valve in instead. If you are interested in this I can show you how its done. Only downside is i have to open the manual valve whenever I want heat, which I rarely use.
Old Mar 3, 2013 | 01:57 PM
Car: 90 Iroc Vert
Engine: 5.0L
Its just strange that it didnt reoccur.
Must have been a pressure burp or something cause of the quick restart I did ?
Thanks guys, I'll just put a new HCV in since I have it, replacing most things anyway ...
Thanks again, misery likes company
Old Mar 8, 2013 | 09:03 PM
Car: 90 Iroc Vert
Engine: 5.0L
Got it to show me a few dribbles of green AF on a restart again.
So I let my 15 YO son install the new HC valve - Couldnt see a crack on the old one.
Old Apr 25, 2013 | 11:01 PM
nugget87's Avatar
I've gone threw 3 of them also I want 2 delete it but don't no how its becoming such a headache
Old May 28, 2013 | 12:04 AM
SkyKitt's Avatar
Car: 1988 Trans AM GTA
Transmission: 700r4 with shift kit
Axle/Gears: Stock
I had the same problem and am going to put in a brass manual valve. I put a Tee (part #15982138 ) in the spot where the heater valve was. I also bypassed the IAC housing. I will post some pictures if I get a chance.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
New2Chevy
Sep 28, 2015 12:35 AM
lakeffect2
Aug 23, 2015 08:44 AM
