86 over heating
Old Mar 8, 2013 | 08:08 PM
ICE43701's Avatar
Car: 86 IROC
Engine: 305 tune port
Transmission: auto
86 over heating
i was wondering if a hole in the gas tank and the exhaust barely hanging on would make my car over heat?
Posted from Thirdgen.org App for Android
Old Mar 9, 2013 | 12:12 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: 86 over heating
Not really. But it makes me think the cooling system is in the same state as your tank and exhaust
Old Mar 9, 2013 | 07:54 AM
ICE43701's Avatar
Car: 86 IROC
Transmission: auto
Re: 86 over heating
Any idea where I would look to try and see? Im debating if I should try and fix the car right now or get a different car and work on this one later
Old Mar 9, 2013 | 12:03 PM
Re: 86 over heating
Define "overheat".
Old Mar 9, 2013 | 01:40 PM
ICE43701's Avatar
Car: 86 IROC
Transmission: auto
Re: 86 over heating
goes into the red
Old Mar 9, 2013 | 03:14 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 86 over heating
Check for water on the dipstick, check coolant level, check fan operation, verify waterpump rotation is correct, make sure the air dam is in place.
Old Mar 9, 2013 | 03:24 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 86 over heating
Plugged radiator
gummed up cooling system
stuck thermostat
failing water pump
Timing set incorrectly
Missing air dam
bad radiator cap
blown head gasket
cracked head
these and more can cause overheating
Old Mar 9, 2013 | 03:25 PM
Car: 1971 Camaro
Engine: 427
Re: 86 over heating
Does it get hot idling parked?
Does it get hot only when driving?
If it has happened more then once and is getting into the red you can cause major damage if you have not already.
Old Mar 9, 2013 | 04:08 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 86 over heating
If it's not boiling over, it's not overheating. Do not count on the in-dash gage to be an accurate account of the actual state of nature at the end of its sensor. Verify by other means.
Old Mar 9, 2013 | 04:17 PM
ICE43701's Avatar
Car: 86 IROC
Transmission: auto
Re: 86 over heating
it gets hot when im driving i cant test it idling because of the hole n the tank the only way it stays running is if i have one foot on gas n one foot on break. water pump was replaced n the head gaskets were suppose to be replaced the fan is on a toggle switch i turn on soon as i get n the car the timing was checked its set right
Old Mar 9, 2013 | 05:45 PM
Car: 1971 Camaro
Engine: 427
Re: 86 over heating
Sounds like you got major issues.
I would start by getting it running right first, then your cooling issue may go away.
Old Mar 9, 2013 | 06:25 PM
ICE43701's Avatar
Car: 86 IROC
Transmission: auto
Re: 86 over heating
thats what im hope by replacing the gas tank n exhaust that the temp will then stay at the correct lvl
Old Mar 13, 2013 | 06:42 PM
c10freak87's Avatar
Car: 88 IROC Camaro
Engine: 305 TBI
Re: 86 over heating
i dont mean to still your thread but my gauge runs into the red before the fan cuts on but i dont think its getting hot the hoses and cap arent that hot is the gauge a common problem?
Old Mar 13, 2013 | 06:46 PM
Car: 1971 Camaro
Engine: 427
Re: 86 over heating
Sending units can go bad, gauges are known for being off too.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
