where are low side high side a/c ports
Old Mar 18, 2013 | 06:12 PM
chaseww's Avatar
Can anyone help me what one is the low side and high side port on a 1985 trans am with a 305 carb. engine? If you need a pic I could post post one, Thank you very much
Old Mar 24, 2013 | 12:24 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: where are low side high side a/c ports
I'm assuming the A/C setup is the same for carbs as it is for TPI. Anyways, the low side port will be the larger port that is on the accumulator (silver cylinder).....The high side port will be the small port that is attached to the line.
If you're measuring the pressure, make sure the engine is off when you attach the lines. If you're adding refrigerant, make sure you ONLY use the low side port. Adding to the high side port will make the can of refrigerant explode.
Fronzizzle
Aug 17, 2015 02:52 PM
TA8487
Aug 16, 2015 12:21 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
