AC Delete 87 IROC 305 LB9 TPI
Old Mar 25, 2013 | 03:19 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
My A/C has been non-functional since I bought the IROC from a buddy. I do not feel like paying the money for a new system or for prehistoric freon...
There is no serpentine belt on this engine. Can't I just remove the AC hardware and the belt and I'll be fine? I want to remove the extra weight and clean up the engine bay.
Kent
Old Mar 28, 2013 | 12:21 AM
scottishtransam's Avatar
Car: 1987 Trans Am and 2009 Jeep Patriot
Engine: 305 Tpi
Re: AC Delete 87 IROC 305 LB9 TPI
Yup it was pretty straightforward on my 87 T/A, I picked up an a/c delete box to make more room. If I remember right I had to change over the little coil plug. Just make sure the system is evacuated properly
Old Mar 30, 2013 | 01:11 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I gained a ton of room, It was the best cosmetic change I made to the engine bay. You gain a lot of passenger side engine bay room. While you're at it, relocate the washer and coolant tanks to inside the front bumper somewhere, there are a few threads on that. I did the one by fueled soul and I used polished aluminum cylinders.
Old Apr 8, 2013 | 12:45 PM
Car: 1987 IROC Z28
Had someone look at the system and all the hardware is intact, just no Freon. I am going to have them switch over to the new fittings to accept the modern Freon as R12 is hard to find/expensive. Going to keep it mostly stock for now. In a year a two I plan on dropping a much more powerful engine and/or rebuild/supercharge the LB9. So when I switch over to the serpentine system I may just delete the AC then...
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
