what O-ring for A/c compressor?
Old Apr 1, 2013 | 08:35 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
O have swapped in an LT1 into my thirdgen and it has the Harrison a/c compressor. I did not have the o-rings in the back of it and I need to find some that will fit, but everywhere that sells them doesn't seem to know which ones they are. Too many sizes to choose from. It looks like they are thick and flat, but again I dont have the old ones to compare to.
What size are they and where can I get them?
Old Apr 8, 2013 | 04:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
O Boy
The fastest way is to get a set of O▬Rings.
Advance Auto Parts part number is 26735.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Apr 8, 2013 | 06:25 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Re: what O-ring for A/c compressor?
You can buy an entire o ring kit from autozone for about 3 bucks. It has every one for the whole ac system including the compressor. There may be 2 sets of rings that look about the right size and the ones you need are the fatter set. But if you get the set it is pretty obvious which ones fit in snug.
Old Apr 8, 2013 | 07:08 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
LT1 takes a different seal kit, 4S part # 26729.
gixxer92
May 18, 2017 11:20 AM
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
BOOT77
Sep 5, 2015 03:55 PM
