Dash Temp Gauge Off? Try this part.
Old Apr 9, 2013 | 11:15 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I bought an aftermarket temp sender from the parts store and my gauge was showing about 30 degrees hotter than it should have been. After doing hours of research, I found that the tolerance on aftermarket senders is really poor. I went on a mission to find the correct part # with a "spade" style connector, I purchased an AC Delco D1885 off Ebay. The gauge is now very accurate. I have a 1989 GTA.
This is the sensor on the driver's head between cylinder 1 and 3.
Old Apr 9, 2013 | 11:47 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Dash Temp Gauge Off? Try this part.
How are you determining the gauge reading? On my 89 there is a 100 deg tick and a 220 tick. There is a tickmark half way between but i have since learned by monitoring temp via laser temp gun and ecm logging that the halfway mark is closer to 185-190 it seems. Not 160 as you would think. At 220 my oem temp sender is spot on. Just my observation but this looks like a nice part to try. I could use a new sender
Old Apr 9, 2013 | 12:27 PM
Car: 89 GTA
Axle/Gears: 4.10
My old sender was showing 240 gauge when the actual temp was around 200.
I know actual temp because I have an Accel DFI and it has its own sensors.
To test the new sender I let the car warm up to 220 by keeping the fans off, and the dash gauge also was reading 220.
I agree with you that the half way point between 100 and 220 is more like 185-190.
I prefer the spade connector because I have headers and this keeps the wire away from them better.
MantyZ28
Nov 8, 2015 06:54 PM
383cam
Sep 9, 2015 06:01 AM
Ian Irvine
Sep 4, 2015 08:08 AM
85Special
Sep 3, 2015 04:21 PM
andy74
Sep 3, 2015 08:41 AM
