83-92 Camaro/Firebird Fan Switch
Old Apr 18, 2013 | 06:08 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
has anybody use this 83-92 Camaro/Firebird Fan Switch it said vehicles the factory cooling fan is not triggered until well over 200 degrees F. This Robs your engine of performance and the tendency to pre-detonate is much greater. This switch will help lower your engine operating temperature by triggering the factory fan at lower coolant temperature. and does it work with dual fan or single fan and what Thermostat will work best with it
Attached Thumbnails 83-92 Camaro/Firebird Fan Switch-fan-swtich.jpg
Old Apr 18, 2013 | 07:40 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: 83-92 Camaro/Firebird Fan Switch
Search, true, true, true, both. Depends on the fanstat temp, thermo is ideally 10-15° colder or the fan will be on constant.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
