86 Z28 fan constant?
Old Apr 24, 2013 | 09:24 PM
bookooroo's Avatar
My 305 fan running constant after and maybe b4 i replaced the rad and 180` thermo. Aloso rebuilt the top end on a new long block. Any ideas? The temp guage doesnt seem to move either. Before it was running over 220' witch was causing detonation due to over heat cond. No fault codes atm...
Old Apr 24, 2013 | 10:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 Z28 fan constant?
If This is tpi and the fan is running constantly the relay is bad or the ecm is bad or you have a wiring issue like the relay wire going to the ecm being grounded or the incorrect memcal is in the ecm. If this is a ccc the ecm is not controlled bye the ecm the relay is controlled bye the single wire cts being grounded.
Old Apr 25, 2013 | 10:26 AM
bookooroo's Avatar
It is TPI. ECM is ok. Any idea where the relay is?
Old Apr 25, 2013 | 10:57 AM
Engine: Lb9
Transmission: M20
I guess you have already checked c1 for being grounded than.
Old Apr 25, 2013 | 11:01 AM
Engine: Lb9
Transmission: M20
The ecm pin d11 is n/c a/c fan switch if this circuit is open or the incorrect memcal is installed in the ecm the fan will be on at all times.
Old Apr 25, 2013 | 01:14 PM
bookooroo's Avatar
What installs memcal in the ECM the CTS? Replaced the fan relay. Fan still on when engine cold. Fan doesnt run with just ignition hot like it sposed to. Also i heard ECM may be bad if yhis were the case the car would run like crap no?
Old Apr 25, 2013 | 05:52 PM
Engine: Lb9
Transmission: M20
The memcal is the engine calibration in the ecm, The ecm can have the driver bad for the fan control and still run fine. The ecm controls the trigger ground side of the relay based on the input from the ect and the memcal calibration. When the car reaches 35 mph based off of the vss input the fan will shut off unless needed. When the engine reaches 226f in most calibrations the ecm grounds the trigger side of the relay allowing power to go to the fan. You need to start doing so electrical testing and start with checking the ecm controlled relay ground wire. If the a/c pressure switch is grounded the fan will also be commanded on.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
