A/C problem: Vacuum lines are good
Old May 27, 2013 | 01:17 PM
806camaro's Avatar
Car: 1990 IROC
Ok, my A/C only blows through the defrost. I checked all the vacuum hoses connections, there all good. The circle part that has all the vacuum hoses on the heater, a/c control is good, not broken. My question is WHAT ELSE COULD BE BROKEN? maybe the ducts? Everything works as its suppose to with heat and cooling controls. Just only blows through defrost. But I do hit a good bump on the road it will start blowing through the vents facing the passengers.
Old May 28, 2013 | 10:13 AM
mrdoke's Avatar
Car: 92 camaro
Engine: 383
Transmission: auto
Re: A/C problem: Vacuum lines are good
I know this is an old post but i am having the same problem it used to switch but now it stays on defrost only
Is there any answer to this
Old May 28, 2013 | 10:52 AM
806camaro's Avatar
Car: 1990 IROC
I can't figure it out, spent an afternoon chasing hoses.
Old May 28, 2013 | 11:07 AM
mrdoke's Avatar
Car: 92 camaro
Engine: 383
Transmission: auto
my vac. is fine 15 img i am thinking that the controller is bad for some reason
Infested
May 22, 2018 11:56 PM
lakeffect2
Aug 23, 2015 08:44 AM
cstrobel65
Aug 15, 2015 10:19 AM
apie2546
Aug 10, 2015 05:43 PM
