Help please odd AC problem won't work on one fan setting only.
Old May 28, 2013 | 07:24 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
My AC works perfectly normal until I put the fan selector on hi then AC and fan just shut off. I replaced the dash control unit and that had no effect. So I changed the fan salvage yard piece and I still have the same issue. Can some one point me in the right direction on what to check next?
Old May 28, 2013 | 10:24 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: Help please odd AC problem won't work on one fan setting only.
Im guessing you have a short to ground. I wouldn't keep replacing parts. See if you can get a hold of a wiring diagram and start looking for shorts. It will most likely be a real pain but I think that is where you will find the answer.
Old May 28, 2013 | 11:15 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Most likely a bad high speed fan relay, located on evap housing underhood.
Old Aug 15, 2014 | 08:31 PM
383RAT's Avatar
Eseibel67 BINGO! You where right except for the location of said relay. It was close to that location though.
Old Aug 17, 2014 | 10:27 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
an indication of a bad relay. its located on the AC housing under the hood. typically, when the relay goes away. all speeds except hi will work.
1992rs/ss
Jan 31, 2025 05:10 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
