AC fan issue
Old May 29, 2013 | 07:44 PM
Tazmanss's Avatar
AC fan issue
Compressor, hi and lo switch, diode plug in at comp coil, silver can (can't remember what ya call it) new freon added by professional installer today to try and get AC working in 87 roc.
Issue-when you turn on AC nothing works, run a ground strap from negative on battery and it cycle on and off for 1/2 doz times then you can remove ground strap and it runs fine, turn it off and repeat, once it worked with no help from strap, then another weird thing, blower and comp would work and left fan would shut off, left fan would come on and comp and blower will quit...any help would be appreciated, stumped at moment.
Old May 29, 2013 | 07:45 PM
Tazmanss's Avatar
Re: AC fan issue
Run strap to ground to blower ground should have made that more clear.
Old May 30, 2013 | 07:03 AM
Tazmanss's Avatar
Re: AC fan issue
Think I figured er out, thanks
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
