Low side very high
Low side very high
Hey guys,checking out moms 86 T/A a/c.New GM compressor 5 years ago changed to R134 by shop back then,worked pretty good.Now mice destroyed it in winter storage and had to completley restore dash/interior.When I put the system back together with a new dryer and white orifice tube,in the correct way,the low side pegs the gauge high.Vaced for 90 mins with Snap On machine,no prob,added 80% of original charge and a little oil.When running today high side was around 225-250 at 80 degrees outside.Low side was pegged.Did all over again and only put in a little under 2lbs,same.Recovered system,took apart orifice to look for crud,its clean.All parts except 5 year old compressor are original.Clutch is engaging as it should,but never did cycle,stays on.Ideas to check???Mom wants her baby back soon or I might have to lend her my 88. theyre twins.Thanks Allan
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Low side very high
Other possible cause is the system is overcharged but for the low side to be pegged I would think the high side would be well over 300psi if that was the case.
Almost sounds like an internal leak with the compressor or the orifice tube o-ring is not sealing properly. You are positive you installed the orifice tube in the correct direction? The short end below the o-ring goes in facing down.
