A/C problems
Old Jun 23, 2013 | 07:35 PM
Kurtis32's Avatar
Car: 86 camaro coupe
A/C problems
ok so my a/c needs work...apparently. i've had the car two yrs now and i think its time for some a/c. never tried the a/c (crazy i know) i just knew it wasnt going to work. i tried it today and surprisingly it actually works, sort of..the a/c just blows the the bottom part of the passenger side, not even thru the vents it comes from some compartment under the glove compartment. its not cold but not really too hot either. does anyone know what needs to be done?
Old Jul 2, 2013 | 04:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Air Is Allll Riiiiight
Does the heater also just blow from the lower right?
Also, first thing to do is get a set of AC gages so you can take measurements.
When the AC is running, and the outdoor temp is 80°, the HI side pressure shoulb be about 190 PSI.
The LO side 45 PSI.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
