Step 1 on my restoration!
Old Jun 25, 2013 | 04:11 PM
DrNBody's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
Just ordered a bunch of parts! This is step 1 of my restoration process for my 86' Z. This is what I purchased:
- ACDelco 15lb rad cap
- Fel-Pro water neck gasket
- Goodyear 61196 lower hose
- Goodyear 61331 upper hose
- Stant Superstat 195* tsat
- Spectra CU951 rad
The rad was the best I can do right now. I'm sure it will be fine.
Now, when they all come in and once it's together, what kind of coolant should I run? I'm getting it locally.
Old Jul 1, 2013 | 04:02 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Re: Step 1 on my restoration!
Everything worked out great. I went ahead and did the "extra flow mod" and drilled four small holes symmetrically around the tstat. I also went and purchased some distilled water and PEAK green concentrate and mixed it 50/50. Runs perfectly now.
Had one code after all said and done, 23, ended up being a faulty plug for the MAT sensor. Got the pigtail and spliced it in this morning, everything is tip-top now.
Gunner242
Dec 25, 2015 04:49 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
David Frans
Oct 31, 2015 08:12 PM
mrbird
Oct 20, 2015 03:43 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
