Primary cooling fan inop
Old Jul 29, 2013 | 04:58 PM
IROCBOY's Avatar
My primary cooling fan will not operate. I have the secondary cooling fan rigged to a switch. I have a 180 degree thermostat installed. The cooling system builds pressure normaly. The radiator was new about 300 miles ago. My 1990 iroc will consistently continue to heat to 260 degrees and the primary fan never comes on. If I disconnect the coolant switch on the manifold the fan comes on. I figured it was a bad switch right? Nope. I replaced the switch twice with two different brands. It will not come on. Has to be an ECM problem now right? Any other ideas? I even changed the engine temp switch in case it was just an indication issue. I'm out of good ideas.
Old Jul 29, 2013 | 10:02 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Primary cooling fan inop
Originally Posted by IROCBOY
My primary cooling fan will not operate. I have the secondary cooling fan rigged to a switch. I have a 180 degree thermostat installed. The cooling system builds pressure normaly. The radiator was new about 300 miles ago. My 1990 iroc will consistently continue to heat to 260 degrees and the primary fan never comes on. If I disconnect the coolant switch on the manifold the fan comes on. I figured it was a bad switch right? Nope. I replaced the switch twice with two different brands. It will not come on. Has to be an EPROM problem now right? Any other ideas? I even changed the engine temp switch in case it was just an indication issue. I'm out of good ideas.
The primary fans runs off commands from the ECM. the secondary fan runs off the Fan switch and both fans should run with the AC turned on. Since your secondary fan is rigged to a manual switch, does either fan come on when you turn the AC on?
Old Jul 29, 2013 | 11:02 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Not sure what you mean by "primary fan"
https://www.thirdgen.org/forums/cool...ans-arent.html
https://www.thirdgen.org/overheating
Read these, carefully, so you have accurate troubleshooting material. Obviously the fan not coming on at all is a symptom. However, which side? When does it overheat? At what speed/conditions? How long has it been doing this? Are you sure your gauge is accurate? (IE you have checked it with a laser thermometer at the autoparts store) Need a little more history & info to help.
Old Jul 29, 2013 | 11:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Good info Keoman.
Old Jul 30, 2013 | 07:36 AM
IROCBOY's Avatar
I have the secondary (passenger) fan rigged to a switch because the AC had been inop for a while and I didnt want it to effect cooling. So neither fan is controlled by the AC pressure switch anymore.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
