Replace cooling fan to start at lower temp.
I need to replace my stock cooling fan + thermostat so that it can start on a lower temp rather than on stock temp or runs continuously.
What do I need to change/replace (besides fan and thermostat) in order to make it happen ?
Would this work or do I need something else ?
http://www.hawksthirdgenparts.com/pr...2C100-CFM.html
I am fed up with the stock setting
Re: Replace cooling fan to start at lower temp.
no need to change fan and stat, you need to chang ethe temp switch or in case of a computer controlled fan (dual fans) you need to alter the tune
I have a single fan right now (Guess it's stock). Where is the temp switch located on a camaro 91 V6 ?
Is is just to replace it ?
Read somewhere that stock fan on 3.1L runs by the ECM. Is it true? And if so where can I get a computer unit to alter it ? Any suggestions ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The ecm controls the fan setting like twin_turbo said, I offer reprograming send me a pm if you decide to go that route. I also have the 3.1 memcals if you can't have the car down.
