overheating 427
overheating 427
I have a 427 bbc with an over heating problem. should i replace the 50/50 coolant with only distilled water ? if not what should i do ? i have 160 degrees thermostat and i cant seem to lower the temperature of the water. i fixed the timing, i have aluminium radiator with 3 electrical fans.
Re: overheating 427
i over heat while driving and on idle ... i did bleed the system and yes the fans are working properly ... i have a feeling that my gauge and/or sensor is defective
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: overheating 427
i think its a combination of timing and the 160 stat your using. The stat is too cold and opening too soon and not letting it cool. sometimes the cold stats doesnt mean a cooler engine
Car: 1989 Iroc Z
Engine: 5.7 L98 G92
Re: overheating 427
Antifreeze and water will cool an engine better than straight water...Also you could try water wetter. I found it dropped my temps in my 360 Dart Swinger by nearly 20*.
Engine: 4++,350 & 305 CIs
Re: overheating 427
Coolant just lubes the system seals and keeps things from freezing in winter.
You can use strait distilled water and water wetter with great results but only in summer.
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Re: overheating 427
Need to know much more about engine to know what it will take to fix your problem. BBC was a tight fit I'm sure. Lot of things to consider with the rat stuffed in there. Heat soak from tight quarters has a big effect on everything, stuff you wouldn't even think of.
