Heater Control Valve eliminate effects
Old Aug 31, 2013 | 12:17 PM
baker440ex's Avatar
Car: 87 Z28
Engine: Roller 305 LG4
Transmission: NWC T5
Axle/Gears: 9 Bolt 3.27 LSD
What are the effects of eliminating the Heater Control Valve? Would like to eliminate it and route my lines off to the side of the motor
Old Aug 31, 2013 | 03:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Heater Control Valve eliminate effects
why eliminate ? can get pretty darn cold in some areas . since you did not show your location in profile we do not know . on the gulf coast where I live I don't need it often . when I do i'm glad I have it . why not re-locate valve ? I and many others have re-located valve to rt. rear (pass.) corner of eng. bay . do a search on "re-locate htr. valve" , lots of info. and pics. . good luck .
Old Aug 31, 2013 | 03:28 PM
ALOT of cars don't have one at all. Instead, hot water flows in the heater core ALL the time.
No reason you can't do that to yours.
Main effect will be, the AC won't be quite as effective.
This would be in the class of things that just because it "can be" done, it's not necessarily "A Good Idea".
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
89mulletbird
Aug 12, 2015 07:08 PM
