Before I embark on the LS1 fan swap...
Old Aug 31, 2013 | 10:52 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I keep reading that this is a very effective mod to do to increase fan performance. I keep seeing people swearing that the LS1 fans are identical to the third gen dual fans, but pull more amps. Can anyone verify this? The only thing that I found is that they have different part numbers.
TPI fans are 15-8988, and Elis Juan fans are 15-8404.
Old Sep 1, 2013 | 06:12 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: Before I embark on the LS1 fan swap...
Im intrested in an answer to this too
Old Sep 2, 2013 | 03:55 PM
If it "pulls more amps", then it's a more powerful motor. (at least, as far as power input)
Most likely it either spins faster or the blades have more pitch.
Old Sep 4, 2013 | 08:39 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Then try a 40 amp taurus fan like I did and your overheating days are gone. I did the pepsi challenge with almost all of them and at one time had five fans hooked to the car and nothing comes close to the taurus two speed fan. My other 3rd gens will have one soon.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
