head gasket replacement help?
Old Sep 11, 2013 | 08:02 PM
Devon Abraham's Avatar
ok yall im almost positive that its time for some new head gaskets. the car runs at normal temp, but only if baby it. if i get on it even the slightest bit it will begin to run around 240ish and im loosing coolant and i just replaced the water pump and lower radiator hose and ive noticed white smoke from the exhaust, but i only notice the smoke once in a while. my question is if i do replace the gaskets do i absolutely have to machine the heads and intake or should i be ok as long as i get everything torqued down in the rihgt sequence at the correct torque? thanks in advance
Old Sep 11, 2013 | 11:01 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: head gasket replacement help?
should check for warping(and cracks)when you have the heads off-chevy heads are kinda prone to warping-even the heavier cast mid-'70s and older ones.Most late '70s up original chevy heads are especially prone to warp.If heads need skimmed,they will have to be stripped of valves,etc.-at that point might as well do a valve job and replace stem seals,check guide fit etc.
Old Sep 13, 2013 | 12:27 AM
ok thanks man. its a 1990 305 and its got right under 200,000 miles on it so i guess i should have expected some kind of problem. Could anyone assist me with part numbers and such for everything i will need to do valves, springs, retainers, etc. the local advance auto crew is just about useless unless i happen to catch the right guy in there so if i go in there with part numbers to match it would probably make my life and theirs so much easier.
Old Sep 18, 2013 | 09:25 AM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
A machine shop will do this for about $300.
Thickness of new gasket is important; they come in different thicknesses and materials.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
MY87LT
Aug 17, 2015 08:43 AM
