Can you help identify this sensor?
Old Sep 12, 2013 | 02:39 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
1992 Z28, 350, dual fans, with AC. Passenger side of engine, between spark plug 6 & 8.
Old Sep 12, 2013 | 02:47 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Can you help identify this sensor?
If this is on the driver's side, it would be the coolant sensor.
Old Sep 12, 2013 | 02:56 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Thanks for replying, but I've identified it on the right side (passenger). From reading the threads, in the picture below, the sensor next to the starter is the "coolant fan switch."
In the first photo, would that be another/different coolant sensor? Thanks
Old Sep 12, 2013 | 04:19 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
The sensor near the starter is the knock sensor. It's further down the engine block.
Not sure whether the 350 block has the coolant sensor on the passenger's side (that's the issue with left and right; you never know from which point of view left is left and right is right )
But the first sensor definitely looks like a coolant sensor and being mounted in the cylinder head strengthens that assumption even more.
Old Sep 12, 2013 | 09:30 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Thank you NCC-2569 for identifying the 2nd picture as being the knock sensor and not the coolant fan switch.
Old Sep 12, 2013 | 08:01 PM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Tuned Performance for helping to confirm that the 1st picture is the "coolant fan switch". The switch itself looked nothing like what is sold these days.
Old Sep 13, 2013 | 10:33 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
You're welcome!
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
