Heater Core Replacement
Old Nov 1, 2013 | 04:33 PM
strahd_zarovich's Avatar
Car: '92 Firebird
Engine: 305, TBI
Ok so I need to replace my heater core. I think I know how, so that is not my question. What else should I look at doing while I am in there replacing my core?
Old Nov 1, 2013 | 06:25 PM
Re: Heater Core Replacement
Speakers, the foam / rubber / whatever spooge it is around the heat control door, any sound deadening or sealing anything you touch
Old Nov 1, 2013 | 07:59 PM
jdawg1276's Avatar
Car: 1988 camaro
new heater hoses
Old Nov 1, 2013 | 08:18 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've noticed little pads on some Thirdgens where the dash pad and dash touches the body. I was thinking it is there to reduce noise/squeaking etc.
Could clean out the HVAC ducting as well.
Old Nov 2, 2013 | 04:00 PM
Car: '92 Firebird
Engine: 305, TBI
I was thinking about doing a little sound deading when I replace the carpet. I would like to do a spray on type while everything is out for carpet.
Old Nov 5, 2013 | 06:48 AM
BlackJet's Avatar
Car: 1988 Formula 5.7
I would suggest an alluminum heater core replacement and careful not to bend the tubes too much on the brass ones, or they WILL leak.
Not sure if you will have the "hidden bolt" on top of your heater box, but I would guess yes. It's a feel for it type of thing. And carefull putting new one in, goes in at an angle to some degree.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
