AC Bypass pulley = Damaged belt
Old Nov 27, 2013 | 08:03 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I installed a AC Bypass pulley last week and today noticed that the belt is starting to fray. The new pulley has the belt snug to the walls and the walls have no beveled edges. The walls of the pulley are straight.
Has anyone else had this problem.
Heres were I bought it= http://www.oreillyauto.com/site/c/de...&keyword=34157
And you can see the fray just on top of the water pump.
Old Nov 27, 2013 | 09:04 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: AC Bypass pulley = Damaged belt
I bought one for my lt1 and had to put washers on it to align right it, was squealing like a pig and doing what yours is. Did you buy the ac delete pulley from autozone? If so i would buy the ac 1le version from gm.
Old Nov 27, 2013 | 09:06 PM
89rs454's Avatar
Car: 1989 SS
Your power steering pump also seams to be leaking.
Old Nov 27, 2013 | 10:26 PM
Engine: TBI,5.0
I found it at Pace Performance but is says =
Description=
This Assembly was originally used on 93-95 1LE cars without a/c This part will take the place of the original a/c compressor, if you wish to eliminate the a/c from your car. This bracket will only work with bracketry from 1993-1997 Camaro/Firebird, Caprice/Roadmaster. Original belt remains the same.
Its been discontinued/not available.
Old Nov 27, 2013 | 10:41 PM
89rs454's Avatar
Car: 1989 SS
Description=
Look for the 87-92 305 tpi 1le here ill find it for you http://www.ebay.com/sch/sis.html?_nk...d=270535574881
This is the one you want http://www.ebay.com/itm/82-92-Camaro-Firebird-1LE-AC-Delete-Pulley-NEW-GM-/291025390438?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c2770b66
Old Nov 27, 2013 | 11:48 PM
Engine: TBI,5.0
OK, please bear with me now,
I found this. This will fit a 1992 TPI Camaro. Everything I have coming up all say that they will also fit my 1989 TBI . The 92 TPI pulley keeps coming up part # 34157 Dorman. That's what I have.Am I not seeing something here.
http://www.ebay.com/itm/88-92-Firebird-Camaro-TPI-New-A-C-Delete-Bypass-Pulley-Bracket-TBI-5-7-5-0-/111218974978?pt=Motors_Car_Truck_Parts_Accessories&hash=item19e52ae102&vxp=mtr
Old Nov 28, 2013 | 12:11 AM
89rs454's Avatar
Car: 1989 SS
The AC is in the same location on all the V8s...Tbi or not.
Old Nov 28, 2013 | 12:16 AM
89rs454's Avatar
Car: 1989 SS
Then again maybe it's not the pulley, what if it's something else? if you already have a good ac delete pulley then you need to look hard and figure it out. A post on the internet will only get you so far.
Old Nov 28, 2013 | 12:20 AM
89rs454's Avatar
Car: 1989 SS
88 92 Firebird Camaro TPI New A C Delete Bypass Pulley Bracket TBI 5 7 5 0 | eBay
that's a cheap junk one you have on it now. you can't put washers on it like i did mine to fix the problem, what happens with these junk ebay parts is there off about a couple washers and it eats the belt and starts squealing the belt. At least that's what mine did and i could see the alignment twisted, i was lucky not to throw a belt on them wot passes and bust my rad to hell. Opti would have got soaked and i would have been ****ed!
Old Nov 28, 2013 | 01:07 AM
Engine: TBI,5.0
I can see on the tension pulley a mark around it where the belt used to be. The new pulley has moved it towards the inside 1/16 in.
That seems to be enough to rub the belt as it moves around the AC Bypass pulley.
Old Nov 28, 2013 | 04:30 AM
Engine: TBI,5.0
I just found this and am going to try it =
http://www.napaonline.com/Catalog/Ca...ctImageWrapper
Old Nov 28, 2013 | 05:06 AM
Twin_Turbo's Avatar
It's a simple setup, a bohrough the pulley with a bearing. Easily shimmed up. There must be some tolerance issues with the casting. I would just take out the bolt and shim the pulley out.
Old Nov 28, 2013 | 01:46 PM
Engine: TBI,5.0
I just thought I would post a photo of the belt on the bypass pulley and where the belt is riding on the tension pulley and you can see how the belt on the smog pump is against the inside of the pulley.
So am I over reacting to this.
Old Nov 28, 2013 | 02:12 PM
Engine: TBI,5.0
Heres the bearings from the back =
Old Nov 28, 2013 | 03:01 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Anyone know of any metal pulleys that can replace the plastic one?
Old Nov 29, 2013 | 05:08 AM
Engine: TBI,5.0
Honestly the more I look at that bypass pulley I’m finding that I defiantly don't like the way it looks, it’s "out of place”. At least the compressor looks like it belongs there. I removed most of the AC plumbing but
I installed the AC Compressor again until I find a replacement. I would actually like to keep it on for awhile. Heres a photo with the compressor.Much better than that pulley.
Old Dec 15, 2013 | 03:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Your belt is too stretched out ! Look at your wear indicator
Old Dec 15, 2013 | 10:51 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
did nobody see the Missing washer face plate?
Ron.U.S.M.C.
in your pic you show the front washer plate. the Big Black one..
i have had my Z28 from the day it rolled off the GM Lot.
AND ALL! of the GM parts and AC Delete Pullys i picked up From GM. always
Had 2 washers..1 in front and 1 in back...
your Missing the back washer plate. the front and back ones are the same.
..take and dig one up. install it and it's fixed!
just cuzz they dont sell them with the pullys dont make them right..
GM had them installed..they came on my car.. and every other 91/92 z28 A/C Delete i have worked on..and seen.
Old Dec 15, 2013 | 12:20 PM
also note:
in the other pic your belt should go.
off the smog pump under crank...buck up over water pump then under power steering.up over alt...
it will shorten that belt up about 2 to 3 inchs also. making it fit better.
http://www.ebay.com/itm/1991-TPI-5-7L-Camaro-Retrofit-Engine-Service-Tag-Swap-/380101597146?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWAX%3AIT&nma=true&si=tINrQNis9Em4s%252BmJTpsMjTsdwf0%253D&orig_cvip=true&rt=nc
Old Mar 11, 2014 | 12:59 AM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
Originally Posted by articwhiteZ
also note:
1991 TPI 5 7L Camaro Retrofit Engine Service Tag Swap | eBay
but wouldnt that reverse the rotation of the waterpump?
Old Mar 13, 2014 | 07:44 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I've done a lot of these serpentine conversions over the years and one thing to pay attention to is the machined seam split on the GM power steering pulley. If it is seperating even a tiny bit, it can shed away at the outside edge of the belt.....front or back or sometimes both. I've had to hand file the sharp corners to prevent it from continuing. And yes, you are missing the rear bearing thrust washer on your delete pulley. Nice to see you are still running the guided idler pulley still.....parts store don't carry that version and GM wants to sell you the whole bracket with tensioner in order to get one.
Old Mar 13, 2014 | 07:49 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
ArcticwhiteZ is correct on the belt routing too....the belt should make an "S" route with respects to the crank and water pump while going under and up the ps pulley.....which would have the belt contacting about half of the ps pulley rib diameter.
no green
Jan 9, 2016 09:22 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
