Both Cooling fans not coming on
Old Jan 25, 2014 | 02:51 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
1989 GTA.. As stated above, both fans are not turning on. I located what appears to be 2 relays on the passenger side..one on the side of the Radiator, and the other laying down and tucked along side the Canister. ALso not sure if it is related but the A/C stopped working around the same time I noticed the fans where no longer working...any ideas before I go out and buy 2 relays for this thing??? could it be something else?? Thanks!
Old Jan 26, 2014 | 05:45 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Both Cooling fans not coming on
One relay/fan is controlled by the switch in the passenger head. Try grounding the wire, should activate the relay and fan. The other is computer controller. I don't remember off hand how to force it to turn on.
Old Jan 28, 2014 | 10:57 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Turn on the AC, that will activate both fans. If they work, then half your work is done.
Old Jan 28, 2014 | 06:55 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Thanks MoJoe, I know about the switch on the passenger head, but I'm just wondering if there is supposed to be two relays for the fan, both on the passenger side..I found the one relay on the radiator shroud, then I discovered the other one tucked behind the Canister??? I Always only read about the one relay on the shroud. Just wondering if this is normal??
Old Jan 28, 2014 | 06:57 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Thanks Ozz, But that's just it...the A/C no longer turns on! It went out around the same time I noticed the fans where not working..I am wondering if these two problems are related??
Old Jan 28, 2014 | 09:46 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
I'm a Chevy guy, and you Pontiac guys do some things backwards! My Google-fu was decent tonight. This seems like what you are looking at.
The factory dual fan has one relay per fan. Two fans = two relays. On the Camaro, both are between the battery and radiator, mounted on the rad support, on the passenger side. A relay on the driver's side is likely a high beam cutout for fog lamps.
Even though location may be reversed on your GTA, there should be a primary cooling fan relay. Then, the heavy duty, dual fan/relay piggy-backs through a plug near the first relay.
This shows the fan relays, lower right. Unfortunately, does not show where the plugs are, like the factory service manual. Follow the large orange wire (fuseable link from battery), and it should lead you to both relays.
With a multi-meter or test light, check the big orange wire for power... make sure the fuseable link didn't blow.
Also, there is a 20A fuse powering the relays... Make sure that isn't blown either. I assume the fuse is "hot in run", so you will have to turn the key on to see 12v on the relay signal wire(s).
Old Jan 29, 2014 | 09:35 AM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Thanks MoJoe!!! This was a HUGE help!!!
Old Mar 5, 2014 | 06:28 PM
BBOWWLER's Avatar
Car: 1988 IROC
Engine: 5.7
Hi - I have a 1988 5.7 IROC with AC - just to confirm, are my fan relays also between the battery and the radiator? My secondary fan DOES NOT come on when the car gets hot and Im trying to determine the problem - Also, could the temp sender near the #8 spark plug also cause this? - thanks
Old Mar 5, 2014 | 06:42 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
One fan is controlled by a temp switch in the passenger side head. The other is computer controlled. I don't recall off hand the parameters were the computer turns on the fan.
Old Mar 5, 2014 | 07:48 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
https://www.thirdgen.org/forums/cool...-diagrams.html
You will be able to figure out which relay is which by the color coding in the page above. It's good advice for figuring out how and when the fans are supposed to come on.
Old Mar 7, 2014 | 05:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
On my 84 T/A, my Fan relay is located on the firewall near the brake booster.
Old Jul 11, 2019 | 08:02 AM
Klleino12's Avatar
Car: 1989 gta ws6
Engine: 5.7
Axle/Gears: 3.47
I changed that one. The switch on the head. Changed it to a 205 instead of the stock one. Still didn’t work
Old Jul 12, 2019 | 01:44 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Did you try grounding the wire going to that fan switch with the key on as described? That would show if the wiring, relay and fan are good.
Do that
Old Jul 12, 2019 | 07:45 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Did you put any tape or thread sealer on the switch? If so, this would cause it to not ground properly, if that's the case. If not it could be a bad switch.
Old Jul 12, 2019 | 08:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
(I'm fully aware this is a resurrected post)
Does the fan come on if you try to retrieve trouble codes ? (It should)
https://www.obd-codes.com/faq/read-g...codes-free.php
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
TheExaminer
Aug 26, 2015 04:59 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
