overheating
Old Feb 18, 2014 | 07:07 AM
miguelc561's Avatar
overheating
I have replaced the radiator. Water pump. Thermostat. And my car still keeps over heating. It doesnt do it when i delute the antifreeze alot like 20/80 but i cant do that cause it geta cold here and i dont want to rust out my motor. What do you guys think it is?
Old Feb 18, 2014 | 08:20 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Is the air damn in place ?
Sent from my XT907 using IB AutoGroup
Old Feb 18, 2014 | 09:09 AM
miguelc561's Avatar
Its a 86 sport coupe 305. Im pretty knowledgeable but i dont know what a air damn is
Old Feb 18, 2014 | 09:12 AM
Car: 1991 firebird
Axle/Gears: 4.10
Its under the front nose of the car big Black plastic piece that catches air and shoves it into the radiator while driving look under the front of the car if u don't c it its prompt gone and u need go put it back .. which I have one posted here for sale BTW
Old Feb 18, 2014 | 09:13 AM
Car: 1991 firebird
Axle/Gears: 4.10
Hawks third gen wants 100$ apiece for em plus shipping I'll take 30$ plus shipping
Old Feb 18, 2014 | 09:16 AM
miguelc561's Avatar
My car overheats at a idle standing still in about 50 seconds i can feel the coolants running threw tje top hose. I dont know why it heats up so fast. If i cant figure it out i might as well drop a real sbc in it and get a 350
Old Feb 18, 2014 | 09:52 AM
Car: 1991 firebird
Axle/Gears: 4.10
U might have air in the cooling system also .. to remove air u need to jack up the front of the car as high as u can and let the motor run with the rad cap off .. also u can pump/squeeze the top rad hose while doing this to help
Edit: did u replace the radiator cap? Does the system pressurize ? After it gets up to temp u shouldn't b able to squeeze the radiator hose hardly at all because of the pressure on inside of hose
Old Feb 18, 2014 | 10:35 AM
miguelc561's Avatar
It makes sense. But would an air bubble really make the whole thing overheat? Ill try it put later though
Old Feb 18, 2014 | 11:01 AM
Car: 1991 firebird
Axle/Gears: 4.10
Depends how big the air bubble is ... is our cooling fan coming on ?
Old Feb 18, 2014 | 11:55 AM
miguelc561's Avatar
Sure is
Old Feb 18, 2014 | 12:25 PM
91ragtopTA's Avatar
Car: 91 Trans Am convertible
Engine: LB9
Axle/Gears: G80/GU2
Re: overheating
I recently bought a replacement 305 for my TA and undone the drain plug on the block and it was blocked with sediment and sludge. (98k miles) well worth a check, may just need cleaning out and a damn good flushing.
Old Feb 18, 2014 | 12:28 PM
miguelc561's Avatar
Yea my whole car has been acting up way to much for only 85k
Old Feb 18, 2014 | 06:27 PM
miguelc561's Avatar
Holy **** you guys never fail! It was the air bubble. A air bubble about as much as a gallon of antifreeze
Old Feb 18, 2014 | 08:31 PM
Car: 1991 firebird
Axle/Gears: 4.10
Hahaha ... that will b 35$ i accept paypal ,credit, debit, cash, or grass Lol JK JK
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
