CTS reading very high?
Old Feb 18, 2014 | 09:42 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ever see one read absurdly high when you know it isn't right?
Yesterday, after like 2 minutes of idling the gauge read 240. I checked everything with my IR gun, I got about 80 degrees on the top radiator hose, about 120 on the surface of the heads.
-- Joe
Old Feb 18, 2014 | 09:50 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: CTS reading very high?
Shorted causes a full-hot reading. Usually in the wiring somewhere. Disconnect it and play with it, see how the scanner reacts.
Old Feb 18, 2014 | 11:11 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hello,
It doesn't bury at 280 or whatever, it just reads way hotter than the IR.
Laptop connected to the ECM shows closer to actual (I believe) temp, but that's the CTS on the manifold vs the head. The head mounted CTS for the gauge is what I'm curious about.
Be it known, I have AFR heads so I have a adapter for the CTS (1/2" vs 3/8" NPT) . I wonder if it being stuck out a hair is picking up heat from the headers?
-- Joe
Old Feb 18, 2014 | 01:02 PM
naf's Avatar
naf
You can test for a short to ground on the guage sensor by grounding the lead and comparing the guage readings. Likely heat from the headers, as you surmise, if that's what's changed.
Factory guages are notorious for being out of whack too.
Old Mar 16, 2014 | 08:10 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Just posted about this in another thread. My factory temp gauge was building resistance in the printed circuit. Not sure why, besides age. But I ended up running a simple electric coolant temp gauge off the head-mounted sending unit to get around this. Plan to do all autometer gauges someday anyway. Hope that helps
Will
specialized
Jun 18, 2022 09:26 AM
GTAman
Mar 15, 2019 11:40 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
GTAman
Sep 21, 2015 09:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
