Coolant reservior
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Coolant reservior
So my radiator is always full, car never runs hot. Air dam in place. Electric fan works great. I have never seen any coolant in the reservoir. If I add water or coolant to it to the cold or hot level, it never stays, does it just evaporate?? Why does this happen? As long as my car never runs hot enough to expel fluid to the res. I guess I'm good, but I always wondered about it.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Coolant reservior
Could be a leak in the reservoir or the hose to the radiator. Could also try renting a pressure tester from a parts store to see if there's a leak in the system.
Car: 1989 Camaro RS
Well the reservior is brand new and the radiator is new as well. I can check the small hose I guess?
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
if you have a heater core in car check that and the hoses that go it mine was leaking at the firewall didn't see it till I was getting gas one day
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cooling systems 101
Originally Posted by techno101
But I never have to add water to the radiator
When the engine cools, coolant is drawn from the overflow tank to the radiator.
That’s why the overflow tank keeps getting lower in your case.
You are losing it VIA leaking or the exhaust.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
