Aluminum radiator
Old Mar 10, 2014 | 09:51 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Aluminum radiator
I am lookin for a decent 4row radiator to keep my temps down. I don't want to spend an arm and a leg. Any ideas? I am having temperature issues now with the stock motor, so I can only imagine what it will do with my new setup.
Any info is appreciated.
Old Mar 10, 2014 | 10:12 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Aluminum radiator
Sounds like you may have other issues. I have no problems with the stock system and my 355
Old Mar 11, 2014 | 07:18 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
What should I look for? I am not sure how to pressure test. I don't see any water anywhere and the radiator is full. I have the fan wired to a switch and it still gets hot in traffic. I have replaced the thermostat.
Old Mar 11, 2014 | 08:01 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Air dam in place & in good condition?
( edit )
You can " borrow " a pressure test kit from autozone. Comes with instructions & can test the cap too.
Old Mar 11, 2014 | 08:04 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Yes, everything is in tact.
Old Mar 11, 2014 | 09:30 PM
joshc's Avatar
Car: 1986 Trans Am
I'd go with a Champion 3 row. I have a Champion 2 row in my slightly hopped up 350 and it stays right around the t stat rated temp.
Old Mar 11, 2014 | 10:08 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
( edit )
Thanks...I will give that a try. What should the pressures be?
Old Mar 11, 2014 | 10:17 PM
midias's Avatar
Have you tried an aftermarket temp gauge? The factory gauge is often really inaccurate.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
