87 Single Fan Question?
Old Mar 25, 2014 | 09:47 AM
87Sp0rt's Avatar
Ive been searching for a little and cant seem to find it, but what diameter is the Single Fan Application and what does it flow it? Ive been trying to replace mine with something better but dont know what to even compare it to, thanks!
Old Mar 26, 2014 | 10:34 AM
87Sp0rt's Avatar
Re: 87 Single Fan Question?
Come on someone has to know out there? Better yet what aftermarket fan has anyone used in place of their stock Single Fan Unit? Ive heard about using 4th Gen fans on our setup but dont know enough about it? Some input would be great, thanks guys!
Old Mar 26, 2014 | 02:29 PM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I read on here somewhere that you can use a ford tarus fan somehow. Its in this section somewhere.
Old Mar 26, 2014 | 02:39 PM
downsouthboy's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 383 w/ vortec heads
Transmission: WC T-5 w/ SPEC lightweight clutch
Any reason you can find the dual fan setup off of an IROC ??? it'll provide better cooling and its not that hard to convert over. Theres my 2 cents. hope it helps. And good luck :-)
Old Mar 26, 2014 | 03:24 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Get the TPI dual fan setup, they flow about 1100 CFM each. Some of the aftermarket low-profile setups don't even compare.
Old Mar 26, 2014 | 10:44 PM
87Sp0rt's Avatar
Wow I had no idea they were that awesome, but thanks that pretty much convinced me to switch over to the dual fan setup, thanks guys!!
krisner89
Oct 10, 2015 06:03 AM
fasteddi
Sep 2, 2015 10:29 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
