How to bypas the engine oil coolant & look factory
Old Mar 29, 2014 | 07:35 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
I wanted to bypass the factory coolant and have it look factory. I used a heater control valve for a 1987 carb 5.0 Camaro since its 5/8 straight through and a 5/8 heater hose from a 99 chevy s10 had to cut about about 3 inches off. My setup is HSR but tpi should be able to use a curved piece and go into factory hookup.
Attached Thumbnails How to bypas the engine oil coolant & look factory-wp_20140329_19_51_00_pro.jpg   How to bypas the engine oil coolant & look factory-wp_20140329_19_51_10_pro.jpg   How to bypas the engine oil coolant & look factory-wp_20140329_19_51_28_pro.jpg
Old Mar 29, 2014 | 07:40 PM
Car: 88 Iroc Z
Engine: L98 350
Re: How to bypas the engine oil coolant & look factory
I used an autozone heater valve and I think an advance heater hose.The pics have the part #s This pic is final install look and I used a 3/4 heater hose to go straight from the heater coil back to the radiator.
Attached Thumbnails How to bypas the engine oil coolant & look factory-wp_20140329_19_51_50_pro.jpg
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
fonzie85
Aug 13, 2015 11:50 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
