AC Compressor Question
Old Mar 29, 2014 | 08:08 PM
ronkay's Avatar
I have a 92 305 that I recently purchased. The previous owner was a hack so things in the car are rough.... Anyway, I'm looking at installing a new AC compressor because the existing one is locked up... Looking at the one in the car, it only has a single two conductor connector that apparently goes to the clutch. However, there's also another connector apparently coming from the AC harness that is just there! Not connected to anything, just hanging in mid air?
Researching the compressor for this model I see there might actually be two connectors one in front perhaps to the clutch and another in the rear, not at all sure what that is...
Can anyone confirm this for me and perhaps included a picture...
Thanks, Ron
Old Mar 29, 2014 | 08:16 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: AC Compressor Question
I've only got an '89 schematic right now, but there is a high pressure cut-out switch. So the power comes to the high pressure cut-out switch first, then goes through that to the clutch connector. While this is a 89 schematic, yours is likely similar to that. The high pressure cut-out is usually on the back of the compressor.
Old Mar 29, 2014 | 08:17 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
one in front and one in back like this
Old Mar 29, 2014 | 09:11 PM
ronkay's Avatar
Thanks to you both for the information.
I will research further but from you have told me and the picture I suspect it is the high pressure switch... Can you tell me if that is part of the compressor or is it a stand alone unit?
Thanks,
Ron
Old Apr 12, 2014 | 05:16 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Thanks,
Ron
I can tell you that the switch in question IS NOT on a new replacement compressor. you may have to buy one from your local GM store
Old Apr 12, 2014 | 07:18 PM
ronkay's Avatar
The picture actually shows the connector for the clutch located in the front of the compressor. It was so fried and mangled I had difficulty identifying exactly what it was and where it went. It should be a standard AC compressor connection so I need to go to the local savage yard and get a replacement plug. Then on to Autozone for a new compressor....
Thanks for your help.
Ron
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
rh76camaro
Aug 15, 2015 12:48 PM
