Need help dont know what to do my car keeps heating up
Old May 2, 2014 | 02:34 AM
Noel_z28's Avatar
Car: 1988 camaro
Engine: 5.0 305
I have a stock 84 camaro z28 5.0 ho with stock fan with a 180 thermostat i replaced the electric fan switch with one from autozone, and my car still over heats, my fans seem to not be working properly they wont turn on unless i spin the electric fan then it will stay on then turn back off after a while while the car is still hot, what do you suggest i do??
Old May 2, 2014 | 06:29 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need help dont know what to do my car keeps heating up
If u have to spin the fan to start the fan, the fan motor is trash and u need a new one. The 180 stat is too cool, should be at least a 195. The factory fan switch wont turn the fans un till almost 230 degrees in some applications so you are better off getting a aftermarket one matched to yous stat temp range.
Fix these things and see what happens.
Does the car have the factory air dam in place?
You may need a new radiator cap as a weak one will let the car get to hot to fast.
Old May 2, 2014 | 06:36 AM
Noel_z28's Avatar
Car: 1988 camaro
Engine: 5.0 305
First of all thanks for the help buddy, i appreciate it,Do you recomend me just get a new fan then? Where can i find a stock one or what do you recommend i get??, I will go with a 195 degree stat then, Yes factory air dam is in place the car is all original from what i know nothing big has been changed ot only has 85,530 miles, cool i will also purchase a nee radiator cap
Old May 2, 2014 | 01:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You do not need a whole fan assembly, just the motor which any auto parts store will carry. Not expensive.
Old May 2, 2014 | 03:15 PM
Noel_z28's Avatar
Car: 1988 camaro
Engine: 5.0 305
Thanks tibo, i went to napa and bought just the fan motor came out to $35.99 and abracadabra it worked no more over heating thanks guys i really appreciate it!!
CRFred
Feb 7, 2016 11:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
